truckramrod
My girlfriend has a 95 nissan 200sx coupe with 2 Infinity Kappa Perfect 12s and I would like to turn it into an IB setup (her current enclosure is about 3.2 cubes port tuned to 38hz).
Anyways the main issue I see is the trunk volume is about 10.5 cubic ft and each subs Vas is 3.5 cubic ft, so ideal trunk volume would be 70 ft, but I only have 10.5 cubes.
Although I read a few posts that said a minimum of 4X Vas is acceptable and another post said:
QUOTE: Its not 10x Vas, its when the Q of the alignment equals the Qts of the woofer. Some woofers don't 10x Vas airspace behind them to achieve this (for all practical purposes).
Would this be worth a try? The current box sounds ok although peaky, it takes up a lot of trunk space and the actual wood got wet and is swelled/starting to split.
