Opinions on Amps
Yea.. I actually bought into the whole Lanzar Opti game few years ago..
I still have a Opti 500x2 that i'll never use again..
It's never been repaired but they are not designed to get the power out of them they are rated for.
I wired up 4 mids to them, 2ohm stereo per channel, re-tuned the gain for mid use.. ran it like that for a couple months and couldnt take it any longer..
The amplifier kept overheating and going into protect.. Got tired of having to shut stereo off for 10min to get another 4 min of play time..
They either need 1 or more fans or better heatsink.
I found out it was thermal issue when i got tired of it and started doing research and finding others with same problem.
See, i ran an external clip limiter in line with this amplifier so i could crank the gain up more to maintain ~28-32v on average output to the mids without them thermally failing but also getting the most power output possible.
Sure.. that's RIGHT at where they are rated at at 2ohms.. but you know what they say.. Koreans are designed to do that.. Pssh..
Not these..
Went to Taramp's where the efficiency went up, cost went down and performance lot better.
wew lad a lanzar opti not designed to take rated power thermally? what a surprise that is! @massivespl will still buy them instead saving a small amount and investing in a real amp like the nendo c2sq
DrzCrazyNigga
DrzCrazyNigga
Milltown NJ
giltyler
