Opinions on a scosche amp?
here are the specs
Amplifier
Recommended Use Car
Width 10.0 in
Depth 13.0 in
Height 2.4 in
Audio System
Response Bandwidth 20 - 20000 Hz
Signal-To-Noise Ratio 98.0 dB
Continuous Power / Channel Qty 60 Watts x 4
Amplifier Output 4-channel
High Level Inputs Yes
Input Signal Voltage 0.2 - 6V
Crossover Active crossover
Crossover Slope 12.0 dB/octave
Low Pass Frequencies 40 - 400 Hz
High Pass Frequencies 40 - 400 Hz
Bass Boost Frequency 45 Hz
Bass Boost Gain 0 to +12dB
Output Power / Total 800.0 Watt
Amplifier Output Details 75.0 Watt - 4.0 Ohm - 20 - 20000 Hz - THD 0.09 % - 4.0 channel(s) , 60.0 Watt - 2.0 Ohm - 2.0 channel(s) , 150.0 Watt - 4.0 Ohm - 4.0 channel(s)
Additional Features Short circuit protection , Input level controls , Thermal protection
Connections
Connector Type Audio line-in ( Screw-type ) , Speakers output ( Screw-type ) , DC power input ( RCA phono x 2 ) , Speakers input
Remote Control
Remote control type None
Remote Control (2nd)
Remote control (2nd) type None
mwe-maxxowner
mwe-maxxowner
lancaster, sc
mylows10
