one sub working harder?
PepsiFiend69
so i was messing around with my setup today, i open the trunk and look at my subs, the one closer to the port appears to be not working as hard as the one farther away, it still sounds good, but one appears to be working way harder than the other, i messed around with my low pass filter and subsonic filter, could that be the problem? now i cant figure out where i had them set at before, i dont even know where they're supposed to be set at. my setup is in my sig. someone please help i am so frustrated. it sounded so good before i messed around with it, and it took me like 3hours to get it set right the first time. my amp is mono btw and only has 1 channel, so its not like one channel is working harder than the other
well if the port is more to one side, you have the pressure issue I indicated above. Now if they both have the same enclosure size, dual ports, same, or even sealed, they will hit the same....but two woofers, one port, and port on one side, you will see pressure differences. Notice on big SPL cars with a wall, they could have 4-6 woofers on the passenger side, and big port behind the drivers side. Well, some woofer have more pressure then the others...
PepsiFiend69
PepsiFiend69
Pottstown, Pa
Polecat
BP1Fanatic
BP1Fanatic
