One sub vs two
wevie
Hmmm... is this a wiring question? Or a sub question? Or maybe an amp question? Ah, hell, general...
Hypothetical question:
One amp (don't really care what kind it is, it isn't important) is wired to one sub at 4 ohms (or 2 or 1, it really doesn't matter).
If you purchased an identical sub and rewired so that the two subs created the same 4 ohm load, powered of the same amplifier as before....
Would you produce more sound?
OK, cone area FTW, that's what I thought.
But, will the two subs split the power output of the amp or will they both 'see' the same power the single sub does? Seems to me that with two subs, all else being the same, the power must be 1/2. If in parallel, the voltage will be the same but the current will split. If series, the current will be the same but the voltage will split. Thus, 1/2 power to each sub.
Am I simply overanalyzing the situation?
squeak stop helping ppl and go answer my question in the thread about time travel and ish //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
wevie
wevie
Iowa
Simek4life
