Immacomputer
Cloud disappear
Clamping and measuring the current and voltage then multiplying them is NOT going to give you the actual power and then when you clip the signal, that value won't be accurate at all either. But I'm not going to open that can of worms.Well you are correct just cause somebody well respected agrees doesn't mean 100 percent it is correct. But honestly there is a thread on there talking about it in great detail. and the sub does move considerably less in proportion to the extra wattage caused by clipping thus less cooling. Just like certain boxes greatly reduce thermal power handling due to lack of movement at certain tones so this could do the same thing.
here read these after this should lock thread cause we both have our beliefs
http://www.bcae1.com/2ltlpwr.htm
http://audioforum.termpro.com/cgi-bin/ubb/ultimatebb.cgi?/topic/8/26576.html that is some pretty good reading there
No, two identical sub that should blow on 600 watts. same box clamp set both amps to do the same wattage RMS . but the smaller amp with everything cranked wide open including head unit (and measure THIS amp like that with the clamp meter and voltage to get true rms) then set the higher wattage amp to do the same power or within a few watts and see if they blow at the same rate. This isn't meant to be a test between a square wave and a pure clean signal so I don't need a scope. this is a test to see if wattage is the ONLY factor in a voice coil blowing. And this is a test that should do that. if they blow within close times we can count this as possibly little variances in build quality between the two identical speakers. if the fully clipped amp blows it in 10 seconds and the other amp takes 90. then it is pretty obvious the different movement of the cone can cause less cooling
I agree with Devil Driver and that's as far as I'm going in this thread. If you choose to believe that the slight change in cone movement (no, it won't move like a square wave and "hang" like you may think it will -- that's just impossible) will greatly decrease power handling, I don't care anymore and you can keep spreading it around. It will only help spread the misunderstanding.
