Sold Old School Planet Audio Big Bang- Very Rare! Must see!
ampjunkielikeme
250.00 shipped firm.... to the cont usa...
this is a super rare old school planet audio big bang -mono block- class A/B powerhouse..
the amp screams sound quality. has a parametric eq built in. adjustable high/low Q setting
built like a tank, it uses large expensive toshiba transistors in the output stage, plus a big highly regulated power supply...it should have no problem putting out more than 1000 watts... ive seen a birthsheet online somewhere that said it put out 1300 watts at 2 ohm..
cosmetics i would give the amp a 8.5 out of 10..it has a few scuffs and scratches.. still looks really good for its age..amp has a clear plexi-glass bottom..
function- 10 out of 10. it works great..
free manual download:
http://www.planetaudiousa.com/support/index.php?_m=downloads&_a=viewdownload&downloaditemid=16&nav=0,1
500w x1 rms @ 4 ohms
1000w x1 rms @ 2ohms
fully regulated power supply. stable up to 16 volts
1 band parametric equalizer
thd -0.05%
signal to noise ratio- 111db
built in lp crossover. with hp crossover rca outputs
strappable to another big bang amp for double the power...
Uh, I have to beg to differ on this remark. I got the 2250p which falls short the rated power it SUPPOSED to do @ 1 ohm...I wasn't very happy when I found this info out googling it.
im pretty sure teedot was refering to the old school PA amps. you are correct though about newer PA amps. they dont hold a candle to os gear
that 2250p is a class d board that is used in many other manufacturers. its almost always overrated , and wont put out its rated wattage..//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
i believe this series is the first amps planet audio came out with...they are all very well built, and use expensive parts . (Internal Rectifier, toshiba, sanken, fairchild....etc).. it isn't anywhere near the same as the newer amps being made today, or after this big bang was made...
i will bet you wont ever find this board in another manufacturers heatsink..//content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
as soon as i get some extra cash for a good clamp meter, im going to start clamping the amps i sell to show the actual wattage output at 14 volts...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thd -0.05%
is this amp still for sale i would be very interested int email me at handsomej07@hotmail.com
Wish I had the money. But seeing this post (and logging on here for the first time in months) reminds me I need to send you my two planet audio amps for repair. I'm also gonna re-check if my brother wants to repair that other amp, so can I ship two or three amps to you soon?
ampjunkielikeme
ampjunkielikeme
nash, tn
Shinju
