Sold Old School Planet Audio Big Bang- Very Rare! Must see!
ampjunkielikeme
250.00 shipped firm.... to the cont usa...
this is a super rare old school planet audio big bang -mono block- class A/B powerhouse..
the amp screams sound quality. has a parametric eq built in. adjustable high/low Q setting
built like a tank, it uses large expensive toshiba transistors in the output stage, plus a big highly regulated power supply...it should have no problem putting out more than 1000 watts... ive seen a birthsheet online somewhere that said it put out 1300 watts at 2 ohm..
cosmetics i would give the amp a 8.5 out of 10..it has a few scuffs and scratches.. still looks really good for its age..amp has a clear plexi-glass bottom..
function- 10 out of 10. it works great..
free manual download:
http://www.planetaudiousa.com/support/index.php?_m=downloads&_a=viewdownload&downloaditemid=16&nav=0,1
500w x1 rms @ 4 ohms
1000w x1 rms @ 2ohms
fully regulated power supply. stable up to 16 volts
1 band parametric equalizer
thd -0.05%
signal to noise ratio- 111db
built in lp crossover. with hp crossover rca outputs
strappable to another big bang amp for double the power...
Nice amp. I've owned several nice Planet Audio amps back in the day. Planet audio amps are so underrated they tend to put out more power then listed @ rms. Good luck on this sale!
Uh, I have to beg to differ on this remark. I got the 2250p which falls short the rated power it SUPPOSED to do @ 1 ohm...I wasn't very happy when I found this info out googling it.
ampjunkielikeme
ampjunkielikeme
nash, tn
Shinju
