Old School Mustang big block SQ build......
Which moter does the Mustang really have
  • Total voters
    60
yeah this is a really ugly car //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Yes it is, the front end is the ugliest thing on the car, i suppose the reason why you havent posted any pics of it. Assuming this is what the front end looks like. (71-73)
I suppose you couldnt afford a nice looking mustang? Im torn between your mustang and the mustang II, which is uglier?
Heres a nice mustang, like i said, after 1970 you might as well scrap em.
[/img]
[/img]
the top one looks better...to me..... It has a lot better curves to it....
I'd love to have a 69 Fastback with a 427 in it. That would also qualify as a "big block" //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
I bet you wouldn't turn down a 351c big block //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
I know a mechanic used to restore old Mustangs then trailer them to Cali to sell at auction. A 351c is more than enough to turn one of those cars into a tire shredder. I hope you are at least planning on converting the drum brakes to discs.
When I think "big block" and old school muscle cars, it's always the 427/428/460 from Ford, the 454/455 from GM, or the HEMI from Dodge that comes to mind.
I still think of the 396 as a big block in the Chevys as well.....The 351c is probably the smallest big block....I plan on converting the drum brakes over
A 396 is a big block....tard. The displacement doesn't determine wheather or not the engine is a big block. And once again, a 351C is a SMALL BLOCK. Ask the owner of the car, he would know.
Maybe you should just stick to something you know. Like cutting grass or washing people's cars? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The 351 Cleveland was introduced in 1969 as Ford's new performance car engine and was built through the end of the 1974 model year. It incorporated elements learned on the 385 big-block series and the Boss 302, particularly the poly-angle combustion chambers with canted valves and the thin-wall casting technology.
Ok. Do you realize what this is actually telling you? Here, let me break it down for you...
FORD did some research on the 385 big block series for performance enhancements. From there, they decided to take those enhancements and apply them to a different engine block. In this case, the 351. Just because they applied the 385 technology to the 351 block, does not make the 351 a big block!
Throughout the years, there's been differing values used for determining if an engine was a "big block" or "small block". Some argue physical size. Others argue displacement. Others argue production HP numbers (ie, non-modded engines). Still others argue the crank journal sizes OR stroke OR....well you get the point.
One make does not fit that mold. That would be Pontiac. The external dimensions of their blocks - from the lowly 301 all the way up to the 455 - share the exact same external dimensions. That's why its so popular to take a 301 powered car and drop a built 400/455 into it. Even all the accessories move over from one block to the next.
From one classic car owner to another - nice car but you don't know much about it. Please take a few minutes and do some reading on your car so that when you actually take it out to a cruise, you can speak intelligently about it.
Here's mine:
1978 Y88 Pontiac ***** Am - PHS documented
**Y88 denotes Gold special edition car. Included gold accents on T-tops which I have in storage, gold emblems instead of red, gold turned dash bezel, gold steering wheel spokes, etc.
L78 Pontiac 400 V8 engine. This is the lower of the two Pontiac engines, the higher performance being the W72 package.
AC/auto/PW/PL/PT (power trunk)
Big 3 done in 4 gauge for now
Knu Konceptz battery adapters - top post. I converted from the stock side posts.
140A 1 wire alt - stock was 60A 3 wire
Currently the numbers matching engine is sitting in my basement and a 1970 4 bolt main 455 punched 60 over is sitting between the wheel wells.
Audio wise - Pioneer single DIN mounted in the map pocket with Pioneer 4 channel amp driving (2) Pioneer 6x9 4ways in the rear package tray. Cost me a little over $300 which was in my budget for audio. Future plans include adding (2) 4" speakers to the center console to bring the stage forward and a sub - probably 8-10" in size in the trunk.
Here's mine:
thats a nice....ride ....my Black ***** AM is a WS4 Y84 one of only 2084 made....It has the gold emblem package also.....I'm not sure how many were black or how many were gold....out of the 2084....I'm just keeping it mostly stock for now since it has only a little over 40,000 original miles....
here is a pic of my Black ***** AM ..I replaced the stock 15" wheels with the Year One 17's....I went with black inserts instead of gold because afer I restripe it it will have plenty of gold...It was repainted in a PPG paint with several coats of clear......
Louisiana_CRX
dem shoes......
Louisiana_CRX
Piney Hills of Louisiana
Louisiana_CRX
