Sold Old School Goodies *Mint Condition*
profoundwill
I have two mint condition old school pieces of equipment for sale.
JBL GTS300 amp. Here are the specs, copied from amp guts:
Power output at 14.4V (20Hz – 20kHz):
2 x 100W @ 4 Ohms (0.05% THD)
2 x 150W @ 2 Ohms (0.08% THD)
1 x 300W @ 4 ohms bridged (0.08% THD)
Fuse: 40A
Manufactured in 1995- 1997
Asking $125 shipped obo
Phoenix Gold EQ215 equalizer. Here are some specs and features:
Features:
15 Independtly Adjustable, Sliding Style, High Q Frequency Controls
for each Channel with 2/3 Octave Spacing
Seperate Left and Right Thru Output Jacks
24kt Gold Plated Input and Output Jacks
Seperate Left and Right Input Sensitivity Controls
Seperate Left and Right Output Level Controls
Seperate Left and Right Input Clipping LED Indicators
Seperate Left and Right Tri-Level Output Level LED Indicators
Pulse Width Modulated Power Supply
Power-On LED Indicator
EQ Defeat Switch
Quick Disconnect Power Plug
3 Second Delayed Remote Turn-On Output
24kt Gold Plated, Two Layer, Copper G10 Glass-Epoxy Printed Circuit Board
Audiophile Grade 1% Metal Film Resistors
Precision Laser Cut 16 Gauge White Powder Coated Steel Chasis
Specifications:
Frequency Response 10Hz to 30kHz
S/N Ratio 105dB
T.H.D. .02%
Cut/Boost +/- 12dB
Thru Output Response 20Hz to 20kHz
Input Sensitivity -12dB to +20dB
Input Signal Range .8 Volts to 32 Volts
Output Level Range -20dB to 0dB
Dimensions
Chasis 11.25"L x 6.9"W x 1.6"H
Overall 11.25"L x 7.9"W x 1.8"H
Both are in mint condition no scratches or anything. Neither comes with box or manual, only the amp and eq. I have refs on here just search. Stock photos can be found on the web.
Please ask any questions you may have.
profoundwill
profoundwill
Birmingham, AL
profoundwill
