Old school amp no specs ANYWHERE
RynoThePirate
I have a carver kmos 2200. And I can't find specs anywhere. I've had people tell me or I think its this. But no one ever knows. I'm gettin a comp cvr to run off it and wanna know if its 2 ohm stable so I can get the dual 4ohm version. Thanks alot if any of you old schoolers can find any info.
Yes Carver made car audio amplifiers with his special, patented technology. Bob Carver is again running Carver Audio it is located up near Seattle and their tech department still takes tech calls on their old Amazing Loudspeakers for home audio so I'm sure they can provide you with the specs to your amplifier.
Hmm. I thought Phoenix gold owns carver. I may be wrong though
Well if you don't mind burning it up I guess you can try it out. I just don't think the heatsink on the Carver's will dissapate the heat generated by a 2ohm load. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
2x100w 4ohm
300w RMS bridgedTwo 25 Amp Fuses
Two Loud Speaker Outputs (Bridgeable)
Two Hi-Level Inputs
Gold Plated Lo-Level Inputs
Gold Plated Hi-Pass Outputs
Sensitivity Adjuster
Setting for Flat/BI Amp
Setting for Flat/Bass Boost
EDIT: run each channel to a coil on the sub...you would get 200rms total and just need to match the gains(if there are two)
I know this is old, but just for the record:
KMOS 2200
100W RMS x 2 4 ohm
170 x 2 2 ohm
340 x 1 4 ohm bridged
I have two of these brand new in the boxes, with the documentation. The specs I am quoting are right out of the manual.
RynoThePirate
RynoThePirate
washington
StuartV
