Old school ***** AM
at least its the old stuff. id never own any of the newer stuff
I know what you mean...I still have my Kicker XS50 and a ZR360 and ZR120 so I could put together a pretty serious old school kicker set up....I also have a set of old Kicker 6x9 subs.....a set of old Kicker 8's bnib....I may run Kicker...or put together Orion with my Vintage Orion collection....I juswt have to look over the car and decide what it needs...
You know Pontiac just went out of business?
what the hell does that have to do with the OP's thread? and they are not OOB retard GM killed the line just like they did with Oldsmobile. to diversify their holdings and reduce debt. do you ever contribute?
is it the W6 model with 4 wheel disc? definately get an energy suspensions hyperflex kit for it. I have the twin to your car in my driveway //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif but mine is a 78 Z with a gm 400. your engine should be a last year run on the 400 BPO engine IIRC unless it has been swapped for a gm engine.
•V8 400, "X" Code - 220 hp
•V8 403, "K" Code - 185 hp
that will tell you what factory was and rated HP.
if it is an original T/A 6.6 it should have had a 4-Speed Manual, Borg-Warner T-10
IIRC you can use Mark VII heads from a 350 bpo and boost the compression to about 10.5:1 ( stock is around 7.5 - 8:1 IIRC)
nice cars good luck with it.
i'll have tol check it all out when i pick it up...it only has 77-78,000 original miles...so not bad for a 30 year old car....I'll post several pics....I'm hoping it has the disc brakes all around...what code for that? as far as cars mines the k code
Here is a pic of the car.....
i have the perfect powertrain for you....455 w/400 ******. Motor needs rebuilt tho. I also bought a Olds W30 (455) for my cutty ... gonna have about 400hp when i'm done with it
I'm gonna try and keep it pretty much original...it will be a Sunday evening cruiser....I figure stock it should be pretty good on gas...I figure 17-18 around town and 20-22 hwy....maybe better if I'm lucky //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Louisiana_CRX
dem shoes......
Louisiana_CRX
Piney Hills of Louisiana
chithead81
