Old Box.. How do I find out what it's tuned at?
juukno
<Mr. JuU KnO>
I have been using this sealed box for my 2 eho152's and i am beginning to wonder if it is out of tune due to the recent problems i have been having. i calculated that the box is 3.8 cu feet each seperated (7.6 cu combined) not calculating in driver displacement.
How do I find out what it's tuned to? And, is this box too bog/small for these subs? It seems like they are bottoming out at 60-75%.
Sealed boxes CAN be tuned. The reason they are bottoming is the large enclosure, 7+ cubes sealed is rediculous for 2 12's, thus mechanical limits are reached at lower power than rated Pe.
fuckin' noobs.
fuckin' noobs.
^^^this
the larger you make a sealed box for a given sub,(in general) you will loose power handling and the sub will have a lower overall responce.
the smaller you make it, the more power it will take/use and will have a higher roll-off.
you can "tune" a smaller than normal sealed box by usning polyfil to stuff in the box. it helps make the sub act as if it were in a larger bax then it is in.
good info bro.. i was figuring that the box had a major role.. it came with the subs so i decided to roll with it.. time to get-a-cuttin' //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
how do you set your amp gain with a dmm by the way?
There is the 16pin connector in armrest of my old mercedes 2006 S350. Any possible way I can stream music from my phone wirelessly(Bluetooth) or...
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
The dirtiest hooker allive gotta smell better than fried Epoxy! (okay, that was a tad bit nasty, but funny nonetheless!)
juukno
<Mr. JuU KnO>
juukno
Palm Bay, FL
juukno
    May 24, 2024
