Old amp help MA1382HX
mxsi64
I am trying to get the specs of this amp(MA1382HX) I have find some specs but I do not know if this is right does anyone knows this amp?????, the specs I find are the next ones:
Features:
Class AB High Current
1 Ohm Mono /.5 Ohm Stereo Stable
200mV - 8V RCA Input Voltage
Tri-Mode Capable
Line Output for Daisy Chaining
18dB Variable 40-120Hz Low Pass Filter
12dB Variable 100-500Hz High Pass Filter
0-12dB Variable Bass Boost
Variable 40-100Hz Bass Boost Frequency
12dB Variable 10-20Hz Subsonic Frequency
0-180° Variable Phase Shift Control
Gain Control
Dual VU Level Meters
Built-in Cooling Fans
Thermal, Short, and Overload Protection
Gold Plated RCA & Speaker Connections
Patented ANL Fuse Holder
Bridgeable
Optional Chrome Corner Plates Included
Stereo
2 x 130W Rms @ 4 Ohm
2 x 250W Rms @ 2 Ohm
2 x 375W Rms @ 1 Ohm
2 x 500W Rms @.5 Ohm
Mono
1 x 500W Rms @ 4 Ohm
1 x 750W Rms @ 2 Ohm
1 x 1000W Rms @ 1 Ohm
On-Board 150A ANL Fuse
mxsi64
mxsi64
El paso, TX
mxsi64
