ok just got my kicker 30 band eq a couple hours ago and installed it ect..
now - the system defently sounds louder and clearer overall (probaly due to the line driver in it - my radio is only 2 volts this goes up to 9) but now my radio at the normal listening volume i used to listen to it at sounds like crap and cuts out... i used a volt meter and set it to the same voltage on the amp... that i used to have it set at (28.2 at volume 25)
i think it might be because my amp is only supposed to take 6 volts tops and this sends 9 - and i have it all the way up tho - i set it like the manual told me
run 0 db 1khz test tone
1) turn radio loudeer than i listen to it
2) turn input gain up until clipping light comes on
3) turn up output gains until the voltage reaches what i need on the amp
but the thing is i set the volume at full and it still didnt reach the voltage i needed (with amp gains turned all the way down) so then i turned the amp gains up to reach that level...
anyone has any input
