ohms what the h does that mean
lastman
14
florida
what does ohms mean , i see people talking about it all the time , for speakers and amps , i see 4 ohms 8 ohms on speakers , they might have more , is any better than the other and why , just trying to understand so i can get the best
ohms means resistence or work done by asystem. The less ohms the more
power(watts). ie: If your running like 600w at 4 ohm, then at 2 ohm it should
or nearly double like 1000w. When looking at amps. You need to know what ohm
their stable. The less ohm you wire subs at the more power subs will pull from
the amp. ie: if you wire a 2 ohm stable amp at 1 ohm the amp won't take it.
this is just a general look at it. Can get mor complicated.
Yeah, if you haven't bought em yet, then get a matching third sub. I would wire them to 1.3ohm, unless for some reason, you have some really...
6
Follow the wiring diagram for the final 1 ohm load for the 6.5s and the 1k amplifier...
Thank you for all your help and I'll let you know how it all turns out. I'm putting it n a kia optima. I hope that it sounds as good as i think it...
10
lastman
lastman
florida
mindensweetness
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
