ohms and all that fun stuff
  • Thread starter Unregistered
  • Start date
  • Replies 5
  • Views 514
  • 1
U
Unregistered
Guest
ok i have a 4 ohm DVC sub... i was looking at some amps and the power levels i want would be wired down to 2 ohms... can i wire the subs to 2 ohms... how will this effect performance, do i risk damaging anything... can someone please explain what all this means?
Yes just hook the pos on one side to the pos on the other side and the same with the neg sides..Its then wired in parallel. It will only work with one sub though..If you wanna run two subs then you would need two SVCs in parallel to make your two ohm load.
Mike
how is it possible to run a 2 ohm load with 2 dvc subs with 4ohm vc or is it?
no, only a 4 ohm load or a 1 ohm load with two dvc subs at 4 ohms per coil
alright let me word it like this for everyone if you had 2 4 ohm type R's with 300 watt rms and a crunch 4 channel amp 125 watts per channel at 4 ohm and 250 at 2 ohm and supposedly only 4 ohm stable i think it would work at 2 though but how would you wire it if it was yours remember i need the watts and dont feel like spending on a new amp and dont want to blow this one either
to deliver maximum power your load resistance ie;subs and your line resistance ie;amp should be equal. lower value inductors =more current=more power=hotter amp
Yeah, if you haven't bought em yet, then get a matching third sub. I would wire them to 1.3ohm, unless for some reason, you have some really...
Follow the wiring diagram for the final 1 ohm load for the 6.5s and the 1k amplifier...
Thank you for all your help and I'll let you know how it all turns out. I'm putting it n a kia optima. I hope that it sounds as good as i think it...
10
Guest
    May 16, 2024
    May 16, 2024
