ohm wiring help
Originally posted by eddie12345 its duel 4 ohm voice coils and has 2ohm or 8ohm operations
If its dual 4 ohm you can only get 2 ohm or 8 ohm load. U need another sub just like it to do what you want to do.
Theres your answer , You cant , Its either at 2 ohm or 8 ohm , You need a dual 2 ohm sub to get to 1 ohm
Originally posted by eddie12345 how would i wire it if i have 2 subs to run at one ohm
Dual 4 ohm subs, wire VC in parallel. Gets you two ohms. Do that for each pair. Then wire the pairs in parallel. 2 ohms in parallel is 1 ohm load. Its really easy to figure out..
Originally posted by Rockman Dual 4 ohm subs, wire VC in parallel. Gets you two ohms. Do that for each pair. Then wire the pairs in parallel. 2 ohms in parallel is 1 ohm load. Its really easy to figure out..
do u have a picture of it
Basically all the positive terminals on the speakers are wired together then ran to the positive output on the amp. Same for the negative terminals only ran to the negative output on the amp.
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
It also lowers the amps efficiency and raises the current draw.
690
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
491
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
eddie12345
u know
eddie12345
glenmoore, pa
Rockman
