ohm wiring help
Originally posted by eddie12345 its duel 4 ohm voice coils and has 2ohm or 8ohm operations
If its dual 4 ohm you can only get 2 ohm or 8 ohm load. U need another sub just like it to do what you want to do.
Originally posted by eddie12345 how would i wire it if i have 2 subs to run at one ohm
Dual 4 ohm subs, wire VC in parallel. Gets you two ohms. Do that for each pair. Then wire the pairs in parallel. 2 ohms in parallel is 1 ohm load. Its really easy to figure out..
Basically all the positive terminals on the speakers are wired together then ran to the positive output on the amp. Same for the negative terminals only ran to the negative output on the amp.
eddie12345
u know
eddie12345
glenmoore, pa
Rockman
