Ohm question on sub
Match the ohms to your amp. If your amp can do 1 ohm get subs that can be wired to 1 ohm. 2 ohm? Get subs that wire to 2 ohm.
ok Ya cause the subs I'm looking to purchase hds312 d2 1200rms each so I'm thinking is 2 ohms and the amp is 2000rms @1ohm so I'll have to wire the subs to 1ohm correct
if you get 1 sub, ya you can wire a d2 sub to 1 ohm.
if your getting 2 subs get d4 subs.
what amp ??
ok with 2 d2 subs you can go with .5 ohm or 8ohm.
or you could do 2 ohm total.
see were for wiring details..
Subwoofer Wiring Diagrams, Two 2 ohm Dual Voice Coil (DVC) Speakers
so find an amp that will do around 2500 rms at 2ohm. but bigger is always better as it gives you head room and you do not have to set gain high. and thats a good thing.
or if you have the electrical get an amp stable at .5 ohms and wire to .5 .
but you need a h/o alt, a good under hood battery ( amg ) and 1 or 2 batterys in the back. all 1/0 wire with 1/0 wire for the big 3 .
in order to run at .5 ohms you need a strong electrical system to support it.
what type of electrical do you have ??
what size alt? what type and how many battery's ? big 3 done ??
use all 1/0 wire.
also dont skimp on the box, get one made for the subs.
use all 1/0 wire.
Can I just get an amp that's 2500 @2ohm or 8
Repoman79
Repoman79
Nj
Repoman79
