ohm load questions
I was planning on running series but everything I read says series adds how many coils you have to your ohm load I have 1 ohm load plus 2 coils wouldn't that make 3
Think of your coils as two SVC subwoofers, each 1 ohm. Now if you took both of these subs and ran them in series, it would go to 2 ohms, or parallel, it would go to .5 ohm
It's the same concept for each voice coil of a subwoofer. If you ran the coils in series, it would go to 2 ohms, for parallel it would be .5 ohm
No, you have 2 one ohm loads, so 1+1=2. Figuring ohm loads for speakers may sound confusing at first but it really isn't. Parallel will divide your load and series will multiply it.
Ex. Three 4 ohm loads in series would be 4x3 or 12 ohms, in parallel would be 4/3 or 1.333 ohms
basically:
series final load = single coil ohm x number of coils.
parallel final load = single coil ohm / number of coils.
Rainelli
Rainelli
CView, FL
brynm
