allllllllllllright...its not like that... a jumper means exactly what I drew in the picture... but I will try that.oh lordy lordy... Well if the amps out, take it to the front of the car. Open the hood. Theres usually a lever inside the car under the dash. Pull this lever, the hood should pop open. Now get out of the car, go back to the front of the car. (Thats the part you see when driving) and open the hood all the way. sometimes theres another lever or latch under the hood to make it open all the way. Now, put a small wire from the battery Positive to the amps Positive, Put a small wire from the battery negitive to the amps negitive. Put a small wire from the amps positive to the amps remote terminal. The amp should turn on.
can't get any clearer than that..oh lordy lordy... Well if the amps out, take it to the front of the car. Open the hood. Theres usually a lever inside the car under the dash. Pull this lever, the hood should pop open. Now get out of the car, go back to the front of the car. (Thats the part you see when driving) and open the hood all the way. sometimes theres another lever or latch under the hood to make it open all the way. Now, put a small wire from the battery Positive to the amps Positive, Put a small wire from the battery negitive to the amps negitive. Put a small wire from the amps positive to the amps remote terminal. The amp should turn on.
