Hey,
Ok so right now my sub isn't working, but every day or two it will randomly start to work for about 1 minute. While it's working it kind of seems that when I turn up the volume it stops working again, if I don't turn up the volume it will work for about 1-3 minutes but then too it will stop working.
I've tried everything I can think of to get it to work but nothing is changing. Here's some of the stuff I have tried:
-Opened the box and re-wired the sub
-Made a new (better) ground spot
-Tried a new RCA wire
-Tried a different HU
-Tried my ipod hooked directly to the amp via 3.5mm to RCA wire
After each of these attempts it would work for a minute or so as always and then stop. The thing that worked the best was when I switched HUs it worked for a good 5 minutes, I tried to really crank it up (my ears/body missed the bass) and then it stopped working as always.
Now I have sort of concluded that it's either the Amp thats doing something wrong or some sort of electrical problem within the car.
I want to test the RCA wires with a DMM to see if they are constantly giving the amp signal, because if they arn't then its not the amps problem (he cant make something out of nothing)
--- With my DMM set to 10 on the AC scale how many volts should I be seeing? 1v?
If I do see the right amount of volts I will conclude that the amp is the problem.
If I don't see the right amount of volts I will conclude that the problem lies in the HU BUT I know the HU is not to blame (unless they are both broken somehow, pretty unlikely) What could be causing 2 different HUs to not be giving out the right signal?!
That might be the key here...
I really need some input on this, i've been working on this for like 2 months! Thanks
