ultimate157
Engineering Student
Um, what 15 requires 5 cubes ?Your lookin' at around 4.4 CF needed for a nice enclosure for 410s and around 10CF for 215s.
TOPIC OVER
TOPIC OVER
4 10w3's around a 13w7 is the best.sounds best if u use 2 15s and 1 10.
preferably the two 15s on the left and right of the 10.
Also it has to be all JL.
3 12's is more than 1 18. its not that hard guys grade 8 math for area of a circle.Did you know 3 12s is very close to 1 18?
El oh el @ this post3 12's is more than 1 18. its not that hard guys grade 8 math for area of a circle.
Doubling the cone area gives you +6dB (holding mass the same). Doubling the power only gives you 3dB. Cone area rules if you can get it.The way I see it, more power pwns more cone area when you are talking about spl. You can have a pair of 12's that are built to take alot of power, and in a correct enclosure, they most likely will own 10 12" woofers with the same amount of power. The more subs will not cancel each other out, but will add more amplitude.
Very close did not specify whether or not it was above or below. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif3 12's is more than 1 18. its not that hard guys grade 8 math for area of a circle.
I still think that power pwns cone area. Really there is alot more factors in the car that needs to be taken care of as well. But what would you rather do when you go to an spl comp? A dd 9915 with alot of power? Or 10 12" pheonix gold subs, with the same amount of power? See where I am getting at?Doubling the cone area gives you +6dB (holding mass the same). Doubling the power only gives you 3dB. Cone area rules if you can get it.
The only reason to run multiple 10's is a possible thermal compression advantage of running 4 10's if they can indeed take more power than the two 15's and this can sometimes be the case, but not always. You don't see these things in pro audio or home audio because is just not efficient from a cost performance stand point. Generally you go large and then you start added more subs. 18's will give you the best distortion SPL ratio and most spl holding all other constraints constant. Most companies don't really make larger drivers so 18's are pretty much the norm for the largest "practical" size you can buy.
In general:
10's subs generally have bout ~0.031 m^2 of area. 15's are closer to ~0.08, so a 15 will give you more area than a 10... Two 10's that move as much as a 15 are probably more expensive to produce than the 15"
Well most are gonna be optimal in 4 cf but after displacemant and port area you are looking at needing 5 cf available to start with for a 15" single sub build.Um, what 15 requires 5 cubes ?
Not sure what your saying. Can you do the math?3 12's is more than 1 18. its not that hard guys grade 8 math for area of a circle.
