10w3v3 help!
polarisfctyrcr1
i got a dual sealed box with 2 seperate chambers that are .6 cu.ft. per chamber. the subs (10w3v3's) need a box volume of about 1.1 cu. ft. per sub. so basically im .5 cu.ft. short per sub.....there is no possible way i can get a bigger volume box.....would it help if i ported it or what can i do with the box i have now?
http://www.subthump.com/images/silve...rb-212amp1.JPG
this is the link to the site of the box i have....
the 10w3v3 only need .65 cuft per sub ina sealed box. you can use about half a pound of poly fill per sub. the poly fill slows down the sound waves inside the box and kinda makes the speaker act like its in a bigger box. if you go ported they need(depending on ohms) any where from 1.125 to 1.25 each.
polarisfctyrcr1
polarisfctyrcr1
minneapolis
thevic24
