not every one knows everything dont make fun of me lol
playyamxz550
Memphis
okay so I had a though today and figured if it matterd or not because I never ran into this situation. say my truck has 2 battries up front and I run 2 power wires of each into 2 amps strapped then i connect the battries would that make it more effienct power wise for voltage because now its a circut instead of just a dead end?
there are 2 ways of connecting them. Series wiring will add the voltages together while keeping only the capacity of one. Parallel will double the capacity but keep the voltage at 12-14. For car audio, if you are going to connect batts, you will want to parralel them so that your amps run safely and get that extra capacity. if you have 2 matching amps though and run them both off of the batts, it wont really matter too much if the batts are paralleled or just separated. Parallel is always good though because its like having one large capacity battery and they will both discharge evenly.
'Normal' wiring is already a circuit. From the pos term of the batt, to the amp, and then back to the negative terminal on the batt (or vice versa, depending on who you talk to). What you are suggesting is simply making 2 separate circuits instead of one. The only possible efficiency advantage would be from added wire mass (less line loss), but if your single wire running back is of sufficient size, this 'advantage' in the double circuit would be moot.
Dont feel bad at all. Nobody was born with knowledge of how electrical wiring operates. We have to/had to learn it some time.
I have all knu 0 gauge in my truck powering 2 18 dc's, would this help outta phase problems people have with subs? because it would keep a consitant power
Wouldn't affect phase at all, no.
And again, if your single wire setup is sufficient, 2 runs of wire will not give any benefit such as more consistent power.
I found this, can it be done with snapon modis ultra scanner which i have...
It might be "ghetto" by today's standards but I used to run a wire off the battery to a switch then to the amp...back in my youth the Police liked...
15
4K
I use bass knob all the time. Some songs it's almost all the way down. Some stuff, 80s music, it's all the way up. Different songs bass levels...
14
playyamxz550
playyamxz550
Memphis
skylineTT
    Jun 1, 2024
    May 31, 2024
