? normal resting voltage on optima yellow?
brian84corvette
hey all.
I have a optima yellow top.
and I believe its going bad on me.
it measures about 12.3 or 12.4 at resting voltage on my dmm.
I try and charge it up more - but it starts venting from those little holes.
so I take it off charger - as to not damage it more I guess.
is 12.3 - or 12.4 a crappy resting voltag for an optima yellowtop
thats under a year old ?
I have the # to contact the optima rep around my way,
maby he can replace it if its going bad.
but I want to know what yall's batts are resting at - to compair how crappy
mine is to a "good one"
so far - im totaly not impressed by optima.
//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
you are over charging or charging at too high of an amperage setting if it is venting,
a typical lead acid battery that shows exactly 12 volts is less than a 50% state of charge, 12.66 volts is 100% charge FYI
alright - thanks guys.
I have a battery charger from sears. use it on 10 amp setting.
maby I should try the 2 amp setting out, and see how it does.
I was un aware that regular liquid acid filled batterys and sealed units have
diffrent resting voltages. I was some how led to thinking that a battery resting at
12.75 is in full charge - but batterys resting less than 12.5 are in need of charge
or are old and worn out a bit. so I figured 12.3 is pretty crappy for a "good"
battery like a optima yellow top.
ive also heard that battery like kenetik are suposed to have resting voltage of 13+ ?
thanks again for all the help guys.
brian84corvette
brian84corvette
coral springs FL.
brian84corvette
