themarques
Hi everyone, first off thanks for all the info on this forum its really helped quite a bit. il get straight to the point.
I recently had the Pioneer TS-W307D2/D4 (please not ive put d2 or d4 as I am not sure which one is installed). I then decided to purchase another Pioneer TS-W307D2 (this is supposed to have a rating of 2 ohm x 2).
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/Subwoofers/Champion/TS-W307D2%7CD4
The current amp is a Sony Xplode Class D 1400 Max Power
http://www.xplodsony.com/specialty/amplifiers/XM-SD61X
Please note the manual for the sub is located here:
http://www.xplodsony.com/files/manuals/XM-SD61X_Owners_Manual.pdf
So my two questions are firstly:
i) Is this amp powerfull enough to push two 12 inch subs rated at 1200w each (I am guessing not but I could be wrong)
ii)What would be the best way to wire the two subs with the current amp and please note 2ohm and 4 ohm confuse the hell out of me so I am very lost.
If the amp is not powerful enough could you guys recommend something reasonable but not overpriced as I am now kind of on a budget.
I hope ive given as much detail as I can to get your guys input on my situation, look forward to hearing from you.
Thanks
Thanks
