noob needs
Airman21
Ohio
noob has questions on what wires i need to buy... my equipment is in my sig i am just unsure as to what size wires i need and the stuff i need i am trying to get all my stuff to gether so i can get it installed somewhere or get someone to help me this will be my first install.. thanks for the help
you need to get 1/0 awg for your Sub amps and at least 4 awg for your components. I would go with KnuKonceptz for your RCA's and terminals. You will need to go with 1/0 awg for the big three. and I aways use at least 12 awg for speaker wire.
yeah i am looking at speaker wire on ebay.. i was thinking 12 awg for the subs and 16awg for the comps is that right? i was looking at the sticky on wires and it seemed like that was right
i would only need to reach from my sub to my sub amp which will be right next to the box so (2) 3 foot stands should be good right
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
3K
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
5
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
8
The link is from JL audio. It’s a how to set amp levels. The process of setting levels is the same for whatever amp.
5
Airman21
Airman21
Ohio
Airman21
