noob heelp with wire
if you wired it at 2 ohms, two channel, you're running 450W to each sub. If you wired the subs in series to get a 4 ohm load, and run the amp bridged, you're still sending 450W to each...
be careful with the gains.
I have the following:2 SVC aura force 12's
250w RMS
600x peak
I hear they hold more?
Profile CA1200
RMS @ 4Ohm 300wX2
RMS @ 2Ohm 450wX2
Bridged RMS @ 4 Ohm 900w X1
What is the best way to wire the drivers to get the most out of this setup
If those subs are 250RMS and SVC(4ohm, I'm assuming), I would just wire them stereo to the amp. Your talking about putting 450RMS to a 250RMS sub...Pretty good shot at blowing them doing that.
actually if they were SVC 4 ohm, it could work out. Bridge the amp, and wire the subs to a combined 8 ohm load. That would make the amp output half of what it could at 4 ohms - 450 ohms to both subs, 225 to each. There you go //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
gutsrage740
gutsrage740
montgomery, AL
JimJ
