Non-working Power Acoustik BAMF-2000/1D
MisterDeadeye
Bannned
Protect mode Power Acoustik BAMF-2000/1D. A friend bought this a while ago, and I'm not sure what happened to the amp, but upon request I can take it apart and look for any glaring damages.
Goes straight into protect mode when turned on -- not functioning correctly.
$90 shipped, best offer, or trades -- trades being anything and everything.
Flat rate USPS, protected well with bubble wrap. I've shipped two head units, an iPod, and other things this way, and no damages have occurred en route.
Specs from Sonic:
RMS Power Rating:
4 ohms: 600 watts x 1 chan.
2 ohms: 900 watts x 1 chan.
1 ohms: 1200 watts x 1 chan.
Max power output: 2000 watts x 1 chan.
Fully Regulated PWM power supply
Wired remote bass level control included
Power and Protection LED power indicators
Adjustable Tuned Bass EQ (0-18 dB Bass Boost)
Hi Speed Digital Circuitry
Full Selectable Crossover (HI,Full,Low)
Four-way protection circuit
1-Ohm Stable
System Distress Indicator
Die-cast aluminum heat sink designed for massive heat dissipation from three sides of the amplifier
Platinum RCA level inputs
Platinum screw terminals
Variable low-pass filter (40-200 Hz, 12 dB/octave)
Variable Subsonic Filter (20-50 Hz)
Variable Subwoofer EQ @ 45 Hz
Signal to Noise Ratio: 100 dB
Frequency response: 20-200 Hz
Dimensions: 11-3/8"D x 8-1/4"W x 2-1/8"H
4/8 gauge power and ground wiring is required and recommended for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
MisterDeadeye
Bannned
MisterDeadeye
Nebraska
Sleeklsc
