Noise from amp with no aux and car off
  • 6
caseyarndt
West MI
There is a static and sometimes popping noise coming from my subs even with no aux cables in the amp and the deck/car off, the noise is still there with everything on and hooked up.
I have changed subs to test and still the same noise.
The amp is a viper 2500.1 and the car is a Chevy cobalt, I have had different amps in the car before with no problems at all.
Any advice or is something just wrong with the amp?
yes the amp is off when its making the popping and static noise
the amp does turn off with the key off. at least the led light turns off
I would suggest getting a DMM and testing your speaker outputs and seeing what and how much power the amp is putting out when you turn the car off. I would test it right away and if you get anything while the car is off, disconnect it right away. Might drain your battery. But you should have zero noise when the car is off.
how long does the static and popping continue after you turn it off? on the output side, it should discharge, and have no power available to make noise. the power supply section needs to operate actively to allow the output section to do anything. are you powering it from a factory head unit? how is the signal fed?
I think it worked .just odd bc it's brand new but I appreciate it man. haven't had any problems yet
Maybe/maybe not. First it's just a guess, but components can change value with temps and this could be normal. Could also be a sign of a cap on...
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
caseyarndt
caseyarndt
West MI
akheathen
Decebal
    Jun 10, 2024
