noise after amp install
charvel74
I need help determining where the noise is coming from. I am only getting the noise from the am/fm radio wether the engine is of or on so it is not alternator noise. I am wondering if it is my rca cables or the remote line to the amp. I ran these two wires together and I am wondering if that would be causing the noise that I am hearing. Also I used the rca cables that came with the amp install kit and wondering if I should upgrade those and see a differrence.
http://www.bestbuy.com/site/olspage.jsp?skuId=7045306&type=product&productCa
tegoryId=pcmcat30100050007&id=1099396976452
Here is a link to the amp kit.
any input would be appreciated .
Thanks, Mark
other useful imformation
deck pioneer dehp3700 mp its an older model
amp. rockford fosgate 250.2 last years model I believe:confused:
I did not have this problem prior to installing the amp. I will check the ground connections again and see if I can find anything.
Thanks , Mark
Ok today I took the stereo out and I grounded the rca cables at the back of the head unit. This seems to help out a lot with the fm signal but now I am definatley hearing the alternator whine on am stations very badly. I drove the car around a bit and I am happy to be able to listen to the sansa-e260 through the itrip without much interference. I will eventually get a new deck that has an auxiliary input on the front so that I can plug in directly.
Any suggestions on AM whine? other tricks?
Thanks, Mark
charvel74
charvel74
hemet
charvel74
