No Sound
193dBman
VA
I just finished hooking up my amp to my front door speakers. All my connections are good: power, ground, remote, both speaker channels, rcas, speaker connection, and rca's to the HU. I turned it on and what do you know, there is no sound. Anyone got any idea how i could fix this? Thnx in advance.
How about ur fuses all of them?
Pull the head unit out again and double check your wiring - I thought I had wired everything up right, and when I did the smoke test, I found I reversed the positive and negative on the right channel. Reversed the wiring, everything worked fine //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Double check the wiring...use an ohmmeter if you need to.
this sucks, i'm getting white noise through my speakers. I ran through everything at least 2 times. all connections and settings. Do you guys think something is wrong with my amp. I mean, it is coming on, but all i am getting is white noise, no matter what volume it is on.//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
The fuses man check the fuses
193dBman
193dBman
VA
biiqdanz
