Nice set of comps for under 800
ryanbssc29
Ok I have a Ford Explorer so all that will fit is 5 1/4's. I want to have very good sound, and I dont need alot of bass b.c thats why I have subs. I'm trying to stay under 800 for one set of comps for the front and coax's for the back, each being run off an amp. I know most people say that you should just keep stock in the back but since they are blown thats not an option. Basically I've been looking at MB Quart QSC, Boston Acoustics Pro50, and Diamond Audio S500s, but I'm open to other suggestions.
IMO
Front- Crystal CSC 50S
Back- Crystal SSX 510
Or
Front - Rainbow CS 230VAN
Rear - might be able to do another set for 800.
Is there someting that I can buy to make 6.5's fit my door, or would I have to make it myself?
dremel? my past components never really fit so made them fit.
I would cut the hole out until they fit then make a ring out of mdf and screw the driver through the mdf/panel.
Boston Z5 (around 530ish on ebay)Boston SX55 (about 130ish)
Those Z5/6's wail. Haven't heard the rainbows but i sure do loves those bostons.
I haven't heard the Seas or Rainbows, but I enjoyed the K2P's over the Z6's. I would love to take the Seas or Rainbows for a test drive, but can't find a shop or person who has them here.
seas lotus reference > all //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I agree that those are great speakers.
ryanbssc29,
With a nice budget like that, have you considered an active system using raw diy drivers?
Mids: SEAS EXCEL NEXTEL - $115.10 each
http://www.madisound.com/cgi-bin/index.cgi?cart_id=1298710.14743&pid=1939
World class drivers used in some high end home speakers.
Tweets: SEAS 27 _ _ _ _ _ - $28.95 each
http://www.madisound.com/cgi-bin/index.cgi?cart_id=1298710.14743&pid=2138
http://www.madisound.com/cgi-bin/index.cgi?cart_id=1298710.14743&pid=2135
There is a lot of talk about this tweeter.
Rear Fill: SEAS CA15RLY -$50.70 each
http://www.madisound.com/cgi-bin/index.cgi?cart_id=1298710.14743&pid=1044
Can use any decent set back there. I suggested just a mid because I don't like full range rear speakers unless it is a DSP surround sound system. Too much high end pulls the image to the rear of the car as the speakers are pretty close to your ears. I would not run the speakers higher than 4-6KHz.
Crossover: AUDIO CONTROL 24xs
My guess is you will need a crossover to high pass the mids if your deck does not have it built in. This is a nice unit.
My guess is you plan to run the DIAMOND D6 amps to power these? If so that is good as they have a built in X-over that goes high enough to cover the 2-4KHz range. A D6300.4 bridged would be good for the front midsas they are 8 Ohms then, another D6300.4 to cover the tweeters and the rear mids. If you want more than two D6600.4 would be in order.
I dont know man that seams like a whole lot of work, and I wouldnt be using the D6's for my speakers b.c they are running my subs. Also this may seem like a noob thing to ask, which it probably is, but how do i know if an amp runs at 8ohms, or in the Boston Acoustics case 3ohms?
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
They have pre-cut wood if you pay extra at the hardware store. Just draw it out. But you'll have to pay extra. Then screw it in yourself...
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
568
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
693
ryanbssc29
ryanbssc29
Waveland, MS
pimpedout97x
    May 12, 2024
Brendon Jenness
    May 11, 2024
