Nice decent sound without subs?
Which 6.5s for door speaker?
  • Mach 5
    Votes: 1 33.3%
  • Kicker CVT
    Votes: 1 33.3%
  • Peerless
    Votes: 1 33.3%
  • Total voters
FAM4LIFE
SHILOH BOY
Looking to get a nice clean sound(Tight Budget //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif) in my truck without subs. I want to keep the space under my seats so I will not do any subs for now. Was looking at going with an Active two-way and since this is the first time that I will attempt to piece this together, I wanted to know what you consider as a good two-way front stage.
Speaker Budget: $150 total
I don't have a clue on what tweets to get. I only know that the dash currently holds 2" tweets.
So far I'm looking at the following 6.5s for the door:
Mach 5
http://www.soundsolutionsaudio.com/shop/index.php?act=viewProd&productId=157
Kicker CVT
http://www.sonicelectronix.com/item_11395_Kicker+CompVT+08CVT652.html
Peerless
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=299-424
Thanks
ok so its limited at mid range. Which is why I'm asking for feedback? Know of any other 6.5 mid-bass speakers I can compare? I orginally was going to put the CVTs in my back door and then run 2-ways up front, but I've changed my mind once again.
Mach 5
Kicker CVT
Peerless
Thanks
if your running off hu power now, get an amp in there.
Yeah. I'm going to get an amp too but first I need to figure out what speakers I'm running. Plus I need to find a decent double din H/U.
This is going in a Titan by the way. There is plenty of mounting space upfront without mods.
Ok. After more research, I've come up with the following:
I need a 6.5 speaker that can cross into both mid bass and mid range territory. This will ensure a good blend with the highs and should work for an active 2-way.
The CVT is out due that it caps at 350hz.
The Mach 6.5M series seems to be a good mid-bass type speaker but lacks a tad in the mid range. Seems to be perfect for 3-way.
The Peerless seems to have that range I'm looking for...58-2500hz.
Now I'm not sure but I have narrowed it down to the two. Heres the combinations that I am considering now for my set-up:
1.
Mach 6.5M $72(2) shipped and the Peerless 830970 2" Full Range $43.81 (2) shipped......This combination should give me a good blend and the peerless should be able to help out in the mid range area. This would be similar to the current sound set-up of the Titan's factory front stage. $115 total
2.
Peerless 831870 $46.16 (2) shipped and the Seas 27TFFNC/G (H1396) 1" $72.61 (2) shipped....This combination should work as well. Since the Peerless covers both mid-bass and mid-range frequencies fairly well, I figured a true tweeter should be fine. $118.77 total
You are gonna have to cross over any mid woofer if you plan on running large amounts of power to them and that defeats the purpose of having a mid that will get down low.
You may just want to invest in a small sub that is easily hidden under a seat or behind it.
FAM4LIFE
SHILOH BOY
FAM4LIFE
Hampton, VA/Waldorf, MD
bamaboy
BP1Fanatic
BP1Fanatic
