Newb needing help
wendt32
hey, i have a 12" kicker L7 4 ohm. im looking at a jl e1800D and was going to wire it in a 2 ohm load. is that a god amp to sub match and most of all is that a good amp. also i saw a hifonics amp (BX1605D) for about $75 cheaper. are the hifonics a good amp compared to a jl e1800D. anyone that can help me i would greatlly appreciate it thanks.
Probably the brutus will put out more power than the JL but the JL is a better amp.
Is your subs are dual 4ohm you'll need a 1ohm stable amp and the Jl is not 1ohm stable.
What's your budget?
maybe we could find a better amp workin with that.
Probably the brutus will put out more power than the JL but the JL is a better amp.Is your subs are dual 4ohm you'll need a 1ohm stable amp and the Jl is not 1ohm stable.
What's your budget?
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif He has a single L7D4. So he would need to wire it to 2ohms //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
http://www.sonicelectronix.com/item_4351.html Call it a day.
wendt32
wendt32
red bud, IL
Cbass
