Newb in need of help with a sub/amp setup
BenzBoi
9
VA
Hey guys, I have a 2003 mercedes s500. I do not want to have to add a battery or upgrade my alternator. Im not really concerned about losing trunk space since I dont really use it anyways. The trunk is pretty big so space shouldnt be a problem. I plan on getting a shop to install whatever I order online. I would like to run 2 12's with 1 amp. I listen to mostly hip hop and prefer tight bass. What would you all recomend and should I go with a ported box or what? Thanks for any info and keep in mind im completely knew to this and figured I would ask the pros before just going with something cookie cutter that is sold at an audio shop.
Huh? You sure about that?
Anyway, I think we need some more info about goals for your system and budget before we can give you a good recommendation. (I'm sure some people will be willing to just throw some recommendations in anyway, though.)
Max space for box: 19 inches tall, and 45 from left to right, 30 inches up and down when looking at the trunk from the rear of the vehicle.
BenzBoi
BenzBoi
VA
Bumpin' Goalie
