SOLD New Treo RSX1500 Amp and Treo RSXbox
Item(s) Description/Condition: both Brand New, Never Used, Excellent Condition. Amp has never been unsealed, manual included
The TREO RSXBox is specifically made for TREO RSX12.44 subwoofers. The TREO RSXBox is a ported enclosure pre-loaded with two TREO RSX12.44 subwoofers. Installation is a snap because the woofers are wired in a series-parallel configuration (4 Ohm final impedance) inside the box so there is only one set of speaker connections on the outside of the box. There is no sacrifice in sound quality or output thanks the RSXBox's high-efficiency ported design. The pair of polished aluminum three inch ports are flared on the end to reign victorious in the battle against port noise. The premium-grade black carpeting is embroidered on the top with the TREO Engineering Triangle logo.
Features:pre-loaded with two TREO RSX12.44 subwoofers
Parallel speaker wiring and single terminal design makes installation a snap
Dual flared three inch round ports tuned to 38 Hz deliver crisp, clean bass
700W RMS Total Power Handling
Matches perfectly with 500-700W amps designed to run at 4 Ohms or 1 Ohm (1 Ohm operation requires re-wiring woofers)
Premium-grade black carpeting embroidered with the TREO Engineering Triangle Logo
Compact dimensions fit in most vehicles
RSX1500 ampTREO Engineering has combined the latest developments with the most advanced surface mount manufacturing technology in order to create the brand-new RSX Amplifier series. A state of the art parts evaluation process allows only
Features:
Double-sided military spec PC boards with four ounce copper traces
RSX2200 & RSX4400 come equipped with selectable frequency low-pass/full-range/high-pass filter for maximum flexibility
RSX1500, 1600 & RSX1900 are bridgeable in a Master/Servant configuration at two ohms for double the power
RSX1500, 1600 & RSX1900 come equipped with low-pass crossovers and subsonic filters for increased efficiency
Extruded aluminum heatsink CNC-engraved with TREO Engineering logo
http://www.treoonline.com/infosheets/rsxbox.pdf
http://www.treoonline.com/infosheets/rsx_amplifiers.pdf
550 obo + shipping
you pay shipping, paypal, USPS money order accepted
http://www.flickr.com/photos/52486906@N06/
5276320449
5276931222
5276931148
5276320275
5276931390
  • Locked
I have a treo ssx motor if that interests you at all?
Amp
133
261
10
384
brandirenee1024
brandirenee1024
oklahoma city, ok
MikeofTulsa
Brendon Jenness
    May 8, 2024
    May 8, 2024
