New to making boxes just wanted some input on whether everything sounds good
rockin15srandy
I just bought a American Bass HD 15 and a American Bass Ph 4000 MD Amp. It came with an enclosure but I cannot get it to fit. I figured I would finally try to build an enclosure for myself I have been lurking for a while and this site seems to have a pretty good knowledge base and got me going building a box with sketchup and using torres box tuning calculator I think I have everything figured out but was wanting some opinions on what else could be done to make it better or something I should change before I build it (which will be the week after Christmas if things slow down a little at work). Thanks in advance for any advice or replies.
That's really too small of a box for these subs. I wouldn't put them in less than 4cf. Tuning would work well though. I don't think I've ever seen someone unhappy with one of these in 4cf tuned to 35hz with 50-70 in^2 of port. Box design looks solid though; very nice for your first attempt.
Yea I was told to get 3.5-3.75cf for the enclosure but space is limited in my trunk and the height is maxed but the width can go another 1 1/2" but depth I might be able to squeeze in a little bit more but then I might run into building part of the box in the trunk which won't be much fun at all. I am also wondering if there might be another way to port so that I can get the right configuration so it will sound good. I like the way most of the L ports sound but am not sure if there is something else that might work better for the space I have available to me. I might be able to get some more height if I change out the 6x9s in the rear decklid and going with a shallow mount but not sure if the cost/benefit would be worth it for the small gain I would get. But then again I also hear people say that they hit really hard in a 2.5cf box so I'm puzzled with the setup to run. The manufacturer doesn't give a recommended enclosure and I can't seem to find many people with these subs that truly know what size their box is, because they had someone make it for them. Would love some opinions on this.
@pro\-rabbit[/MENTION] @double 07[/MENTION] @Buck[/MENTION]
P.S. For a slot-ported box, I really don't think that much bracing is necessary. I mean, too much won't hurt - but for a little more internal volume, you could do without a lot of those braces.
rockin15srandy
rockin15srandy
kalamazoo mi
Full Tilt
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
