new system
paoli22000
I have a 99 Grand Cherokee and was thinking about putting a system in. I listen to pretty much all types of music depending on mood. In the past I have done all sealed system but was thinking of doing a ported system now just for more sp.
Any suggestions on subs and amp combo's? In the past I had a 4 JL 10W0D2's running off of two Old School PPI surf board's that sounded great!!! That was a sealed box with about a 1.5 cubed per sub. I also had a Kicker 12L7 running off of a MTX 6500D in a ported tuned too about 37hz. Two RF HE2's running off of a Alpine MRV 1507 in a sealed box.
Currently I just have a Pioneer DEH-P8600 running factory Infinty Speaker's in the Jeep. I was thinking about a couple 12" RE's or a single 15" RE. How are they as far as sq? Give me some idea's guys. My budget is around $800-$1000 for subs and amp. Anyone suggest some decent fronts and rear's? I was thinking either PG or I did see some Cadence that had pretty good specs. I would be running the fronts and rears off a four channel 75watts rms alpine amp. Thanks for all of your help in advance. Also would not rule out used equipment.
subs a would say on 15's(RE's,sundown nightshades,FI BL,SSA ICON,DC AUDIO LVL 4....and about the amp a sundown 3k..i heard good things about those babies...
The Sundown 3k would pretty much eat up his budget. And that's if you can find one.
http://www.audioque.com/aq/order.htm
Get 2 HDC3-15s and the 2200D amp. All 3 shipped come up to 967 shipped to you.
I use the same 15 and the same amp. It's a great combo.
If you want to buy used, that would save you more money
I would sugest you stick with a sealed enclosure. Reason being you can get the new Mag v4 12" that are designed for sealed enclosures and they sound awsome for all genres of music. Very loud, with a superbly clean and acurate sound. They have a 4.75" mounting depth and use a 1 cubic foot sealed enclosure per sub so you can save yourself some room too. Amp I would go with the a Sundown Audio SAE-1000D simply cus its a good match up for the Mag v4, reliable and im pretty sure you can get away with the lot 2 sub and 2 amps for under 1100, or you could always just get the subs for under $500 and find a pair of used amps on here. That way you will have some cash left to build yourself a new enclosure out of MDF. Here is a link where you can check the Mags out for yourself. http://www.stereointegrity.com/mag.php
paoli22000
paoli22000
south wayne, wi
paoli22000
