new system
post what amp you have and its' specs since you want to keep/use that. also budget for subs would help, and system goals.
its a mtx 6500. it says d technology.
i have 2 mtxs but they sound horrible. i like loud but also want something that hits hard. sq is good.
250 watts x 1 at 4 ohms
500 watts x 1 at 2 ohms
775 watts x 1 RMS dynamic power
Adaptive Class D Technology
variable 40-200 Hz crossover, 24 dB/octave (since the amp is strictly for low-frequency reproduction, the crossover is always active)
preamp outputs
compression circuitry guards against overdriving speakers during loud musical passages at high sound-pressure levels
EBC2 port for multi-amp external control of bass boost
high preamp input capability (up to 8 volts)
PWM MOSFET switching power supply
gain control
Thunder EQ bass boost (0-18 dB at 40 Hz)
rubber Iso-Feet allow you to mount amplifier without the mounting screws contacting the amp's chassis
speaker-level inputs with SmartEngage
11-7/8"W x 2-3/16"H x 9-3/4"D
is that amp 1ohm stable do you know? if not, on that amp i'd just get one decent sub and run it at 2ohms. if you have the room for a 15" a maw15 would work very well with that power.
i listen to alot of country and thats part of the problem im haveing with my 7500s its mushy its not tight and it doesnt hit as hard as i think it should
. could the 15 hit with country and if i built a sealed box could my mtxs hit harder?
those hxs' are nice subs. but i'd forget the 6x9s' and get a nice set of components for the front and a 2 channel amp for them.
well i just got an email and he sold them. i havent had much experiance with car audio. im 16, all i have had are 10 inch fosgates,10 inch mtxs, and 12 inch mtxs. i liked the fosgates but i burned them up. i like to listen to my music loud. but nothing seems like its enough. if i sell my 7500 without a box to get something new what would be a fair price?
94 one ton
94 one ton
Farmington mi
94 one ton
