darron016
This is my first post, feel free to move it, if it is in the wrong section.
Okay, I don't know much about car audio so everything I'm about to talk about i just learned in the last week. My friend from work says he is very good at car audio so I bought 2 12's kenwoods in a bandpass box. He comes over to hook it up, we get everything working but only one SUB is hitting and the other one sounds blown or doesn't hit at all.. The next day I start my car, and the bass hits and than instantly turns off, I check my battery connection and it was loose, come to find out the ring terminal was too small, and he just had the wire loosely touching the battery.. But even with this loose connection it was working last night..
Couple questions.
1) Does the connection to the battery need to be tight? Or does it just need to touch the positive charge?
2) after doing research on the internet, they said you should have a fuse holder on the power cord.. I just have a power cord running straight from the battery to the amp.. Is this a problem?
3) The amp won't turn on anymore whenever I connect it to the battery, even though I cannot get a secure connection to the battery. Is it because the connection is loose, or do you think I blew the amp?
4) He didn't disconnect the negative charge while hooking up everything, how can I tell if amp is faulty? Even though it was just working last night..
5) When everything was up and working for the 30 minutes last night, only 1 sub was hitting. Is this from bad wiring, or did I buy bad subs?
Thanks for any replies, this has been driving me crazy and I live in a small town and there is not many professional car audio places out here.
Couple questions.
