panteramatt
I just got done installing a Helix 5 channel amp and 2 sundown sd3 10's. They each have 1 cuft space and the the subs are wired at 1 ohm. The amp IS 1 ohm stable and the subs are wired correctly as I checked with an ohm meter. They just arent hitting hard at all. Im sure its my tuning as Im a novice. Heres my settings:
Bass eq set to 0
Gain level set to 4v as that what my pioneer headunit puts out.
phase-0
subsonic filter-20hz
LPF- 60hz
The only way it hits hard is if I turn th egain or the bass eq up but then it goes into protect mode. What am I doing wrong here?
Bass eq set to 0
phase-0
LPF- 60hz
