New set up, new to systems. Help!!!!
SunnyD
10
Utah
K guys ill be running a hifonics brz2100 with 1/0 welding wire, big 3 upgrade, stock alternator and battery. I'll be powering a sundown audio e15 I. A ported box around 3.5^ feet but not positive and do not know what it's tuned too. Any suggestions, and what should I set my SPF too??
Thanks
Another question, does is matter matter what test tone use to tune my amp? I've heard 60hz but I'm not sure. My sub is a sundown E15.
I always use 50hz, AC out the wall socket is 50hz so DMM's are optimised to read that frequency.
497
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
848
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
901
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
  • Locked
Send me all the items. Once I receive them, I will verify everything in your classifieds. If someone buys them, I will ship out. You would just...
SunnyD
SunnyD
Utah
SunnyD
