new guy that needs help.PLEASE!!!
jbutla925
First off hello my name is jaren I'm new to the site hopefully to get some help.
Ok here is my question: ok I'm running my rca jacks from my amp to my deck but I'm getting no signal to the amp. The rca's are good and my amp is goot because I tested them but when I plug the rca's into the back of my deck I get no signal to my subs.
and make sure you have the remote wire connected correctly from head unit to amp. that tells the amp when to come one and off basically. you might not even have the amp on if its not connected. make sure the amp is on, then mess with the RCAs
Yes my amp is hooked up right everything is hooked up right. I use to run it from a line converter and that worked fine but now I wanna run it to my deck and when I did I didn't get a signal. Could my deck be bad?
jbutla925
jbutla925
pittsburg
jbutla925
