New fuse blew right when it touched
alright then lolits sounds good...
ill get a 30amp fuse BUT I still gotta find the problem about the fuse blowin righta way
30 will still probably pop. good idea's to look at are right were the pos. wire goes though the firewall, and where the wires go into the amp. sometimes u get a stray wire or two that wiggle over to the neg. both those will make a fuse blow right away.
edit: or maybe there is something blown inside your amp. does is have a fuse on it?
First you said your fuse blows when touched. Then you say it blew 30 minutes later. Which is it? //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
That 30 amp fuse will blow as well. While a fuse is the proper device to have blow rather than output transistors, you're going to get tired of replacing them.
Just put a 40-50 amp fuse on it, and be done with it.
it ran for 30 min's then blew the first time, then everytime afterwards. thats why i threw in a bad amp.
AMP IS BLOWN! //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Brother and Dad were checking it all out and a lot of smoke came out of my amp.
Brand new 600watt amp...go bye-bye
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
New boat anchor? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
GrandCherokee
GrandCherokee
Orlando, FL
GrandCherokee
