New fuel line?
Yea they dont have anything in stock.
I just checked pep boys, I wonder if the fuel line repair kit will work?
There is a cut in the metal line from pulling it off the trailer a few months ago.
We thought we fixed it, but now its leaking again.
well if you can take it off and have acess to a tig welder id say drain it, wash it out and le tit air for a bit then hold a lighter next to it i guess to make sure no flamable fumes then weld the crack //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
If i were you i wouldnt be screwing around with the rubber lines. If you are going to take the time to fix it i would do it right. If it is steel brake line i would just go get some of that and go that route. IMHO
Got what I needed, installed it, and its leaking even more now.
How do I make the seal between the connections really tight?
Im going to go down to 5/16 instead of 3/8 and see if that helps for the tubing size.
Im using those metal clamps that you screw to tighten down.
so is it a rubber line or steel that has the initial problem...?
and the size of the new hose should be just big enough to fit over the old line, but this wont work if u are workin with rubber lines. My advice came from a leak in a steel line
btnhfan
Hail to the King Baby!!!!
btnhfan
CT/ GA Tech, Atlanta
btnhfan
Mike Mccabe
