Mopey
I just installed an IDMAX sub in a fiberglass enclosure i built. I pretty much guesstimated the size, and it came out a bit bigger then i wanted. I know for an IDMAX, the enclosure shoudl be around 1 to 1.3 cubic feet. If it is a bit bigger then this, will it make the bass sound weak and muddy? If so, can i just secure something solid to the inside to shrink the effective air space?
When i have the head unit EQ on flat, and no base boost or anything, the sub is barely audible from the drivers seat...I'm not sure what's wrong. I reground at a few locations, making sure to properly sand, and tried grounding directly to the battery as well, all giving the same result. The sub will get loud if i turn the "loudness" setting on the HU up, and increase the base boost and all that crap, but i wouldn't think i'd need to. The base sounds shitty when i do that anyways. The cut off frequency is set to about 70 HZ.
Equipment:
Pioneer 780mp
PG Xenon 600.1
12" idmax
2 channel rockford fosgate
Rainbow SLC 265
pics:
Thanks
Equipment:
Pioneer 780mp
PG Xenon 600.1
12" idmax
Rainbow SLC 265
pics:
Thanks
