new Electronics HELP
Tek18
5
KY
HEy guys,
basically done most of my research on crutchfield.com.. so im looking for other imput i have talked to sales people there and they recommended this
( 2005 Toyota Highlander NO JBL SOUND SYSTEM )
2x the Polk Audio DXi 650s
and 1x enwood Excelon KDC-X395
for front and back //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
and they have said the b24 and m2250 would be a great sub/amp combo. but i want maybe more of a bump , anything past that is like $1000+ for the sub and amp combo, im looking to spend $700 on a sub and amp together.. any suggestions / tips?
Thanks //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
-Tanner
what is your budget for the front stage? do you plan to amp them? any idea on the size and number of subs you want? how much space are you willing to allocate for the sub box? also what type of music do you listen to?
i'm sure the guys can steer you in the right direction once they have some answers.
$700 is about what I've spent on my entire system, so that is a massive budget for sub an amp in a daily driver. Unless.... that is, you are looking to buy from Crutchfield, then you will spend exponentially more there. It's an ok place to do research, but not ideal at all to buy from.
Polk and Kenwoods are both pretty mediocre. Perhaps if you provided us with an overall budget we could help more. Also, your system goals, listening styles, what music you listen to, and how much space you're willing to part with in the rear cargo area.
My parents have an '03 Highlander, pretty good mid-size all around, quick as well, great handling, and not too shabby in the dirt.
Sorry for not being specific enough!
Head unit - $130ish
Door speakers - $100ea or so
Sub + amp = $ 700
I was looking for a box for 2 12"'s originally, i could deal with a box about that size. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Post links to sites that are great sellers that i could order from also, i would love that as crutchfield is very expensive :S
door speakers - spend more $ on the front set and get components, use coaxials for the rear if you even need them. i'd add an amp for them or your front stage will not keep up with the subs.
some components in your price range to check out, make sure they'll fit the highlander:
Image dynamics ctx -6.5 $159 woofersetc.com or sonicelectronix.com
Morel Maximo 6 1/2 $129 amazon.com
Polk Audio db6501 $109 sonicelectronix.com
front amp $80-$139
mb quart
autotek
subs $109-$279
sundown
sound solutions audio
skar
incriminator audio
sub amp $169-$219
mb quart
hifonics
you also need a wiring kit, dampening material for the doors, and build or have built a sub box.
online places that are reputable:
sonicelectronix.com
woofersetc.com
soundsolutionsaudio.com/store
amazon.com
you have a couple options:
1. a 4 channel to run front and rears
2. a 4 channel bridged to run front - allows you to buy lower rms (ie less expensive amp generally)
3. a 2 channel to run front and you can run the rears off the headunit
100 rms per channel is a good fit for those components. i believe they are all rated at around 100 rms.
if you use rear coaxials they typically are rated lower rms so if you put them on the amp, adjust the amp rear gain conservatively:)
Tek18
Tek18
KY
DukeNut
